Upper Rad Hose
Paul King
MrPJK
Ontario Canada
I have a 66 Dodge Dart 273ci with factory A/C ,I seem to be haveing a hard time locateing a upper rad hose ,anyone else haveing the same problem or a solution .i have a gates part #20416 but it dosent seem to work .Thanks
Jeg's shows 2 in stock, O'Reilly shows to stock them, Amazon shows them, & some others all are priced about $15.00.
I bought a hose that worked and always wanted to get a correct one. Thanks all for the info.
Dayco 70825? The hose in my photo is a very popular one and reaches around the A/C compressor i believe.
You will need the correct thermostat housing. Probably not the one that exit's straight up but at a angle.
I beleive this is a non A/C setup
Wow, the simple A/C hoses mentioned above don't look anything like the one on the red 65 in the sale ad. I wonder if I have any photos of a A/C 273.
This hose is used a lot but with the newer style thermostat housing. (not the cast iron one that is angled)
This is what mine looks like,But i have the A/C compressor out at this moment ,and that is the old rad hose .waiting for the new one in the morning.
