67 gt
A Wog boy who loves his Mopars !
The Mailman delivered this today. Looks like a nice piece and I hope it helps controlling some crank case pressure I’m having . Engine doesn’t burn oil, it just pushes it out of the rear main not bad but noticeable If I run it the std way one passenger side pcv drivers side breather if I run the 2 pcv one on each end of the sniper not one drop from anywhere. Doesn’t pull any oil up the hoses as I check them on the regular and they are bone dry. Checked vacuum and I’m pulling 13 hg @ Idle. I’m deciding weather to run a catch can as I do have one just trying to work out where to place it . Will set this up this weekend . Pretty straight forward by the video.
