Skeeter007
Skeeter007
PST bars also arrived also if I forgot to mention that.
You need the disc brake ones. If you can't find the factory ones, just make sure they're at least grade 8 and fit snug in the hole.Just ordered all my conversion parts to swap over to disk brakes. I can’t see any listings for bolts for the lower ball joint to spindle. Will my current bolts, lower ball joint to drum spindle work? (1971 drum fronts) or am I on the hunt for them? If I’m hunting what am I looking for?
Actually, that lower control arm started in 1962. The first sway bar LCA's started in 1965 and was the same in '66. The tabs were slightly different than the '67-72 version, but, they do interchange and will work with the factory bars in their respective years. If the OP is going to use an aftermarket sway bar with his '71 K-member in this swap, I would probably use a LCA without any tabs, unless you can find an aftermarket one that uses the factory tabs. Find the sway bar you wish to use and see what the manufacturer recommends or requires.Lower control arms without sway bar tabs are the same for 63-76. The sway bar tabs that are located out by the lower ball joints are 65-72. Tabs located 4/5 inches away from the ball joint are 73-76 and are used with the 73-76 sway bar which does not fit the pre-73 K Frame. It appears you have the 65-72 style LCA’s which will work fine with the disc brake swap. I’m using the 73-76 disc conversion with 65-72 LCA’s with a sway bar
1/2 inch diameter bolts are used on 1972 and earlier DRUM brake cars. A body.
9/16 inch diameter bolts are used on 1965-72 DISC brake cars. A body.
5/8 inch diameter bolts are used on 73-76 disc, drum, brake cars. A body.
FYI
I keep these in stock.
[FOR SALE] - Bolts, Lower Ball Joint To Spindle. A,B,E, Body. Disc & Drum Brakes.
Nice!!!!
Thanks for the tip. I’ll check it in the morningMake sure to check the new cam bolts against the old ones.
It was awhile ago, but there were some that weren’t threaded far enough down the bolt so the washer and nut would bottom out before the bushing was squeezed down. So the alignment wouldn’t hold. And then if you do something like torque the ever-living-crap out of the bolt, rather than investigating what’s actually wrong, you can have a bolt failure. Wasn’t me, but it definitely happened.
Good practice anyway, not all the reproduction stuff matches the originals and it can cause issues.
......................Make sure to check the new cam bolts against the old ones.
Another FABO member had some that had flats on 2 sides. They failed.
Looks good!
"pro tip" huh?I mean, I don't want to say "I told you so" but using the LCA's to remove the torsion bars is hands down the easiest way to do it, and no fancy torsion bar tools are needed. Heck I had a Mancini torsion bar tool I bought before I knew better, I sold it because I never needed it. They don't fit torsion bars much larger than 1" very well anyway.
I'm a little concerned about one thing though, using the later 73+ strut rod bushings on the earlier strut rods. The 67-72 and 73+ strut rods are not identical, they were actually designed for use with the bushings that were for those specific year ranges. The effective length of the strut rods was the same when using the right bushings, but, the threaded sections and the "stops" on the strut rods for the bushing cups weren't in the same place. So using later bushings on the earlier strut rods might cause you alignment issues, specifically with caster. In an extreme case it could also cause binding in the suspension as it moves through the range of travel.
