A500 with Lokar Kickdown
Do I use the A500 arm? The pin is pressed. I have no problem drilling it out and putting the lokar pin in. I also have a 904 arm, which is longer.
@TrailBeast
I used the 904 arm and it works just fine.
I also limited the minimum the TP is allowed to return with a small clamp on the cable up at the carb end so I can set the minimum it can return.
That lets me set my minimum shift point speeds and RPM's.
Just something to think about.:D
