https://www.amazon.com/dp/B07WGNQ1TN/?tag=fabo03-20
Pretty cheap. Think it’s junk?
Ebay shows the same set up/ price as wellhttps://www.amazon.com/dp/B07WGNQ1TN/?tag=fabo03-20
Car wont be driving for a while, but I'll check solenoid action. ThanksGot two of them in Dusters......one is a couple of years old....other only one season...
Summit ones i returned two of them that was DOA
Hopefully the quality of the product is one step above the IQ of the proofreader.
Yes. I should’ve mentioned I’ve used one plenty.I’m I
Is I know, but are you steping on the brake pedal first b4 you switch it on. Kim
They don’t make em like they use ta. I can only imagine that they aren’t the same any more. I should’ve kept one of my old ones. They probably are still working.i put hurst line lock in my dart back in 1969, removed it in 1976, installed in my duster in 1976, been using it ever since, car has over 4000 runs on it, with stick shift ,
