273 overheating after new timing chain set and waterpump
"There must be 2 threads on this... or the other I answered last nite at 11 pm and it was deleted."
Was that before or after the 12 pack..........Just kidding
I deleted the other one. I can usually merge them but couldn't find this one until after the delete. Duplicate threads can be darned confusing for the members and can be a pain in the azz for the moderators.
I would start by pulling the thermostat, is it possible that you put it in upside down? It has done been done many times before don't ask me how I know that. by pulling the thermostat you eliminate it from the equation also you should be able to see a steady flow of water through the top of the radiator
He stated engine was fine after a T stat change last year, and did not start getting real hot until "right after" he replaced the water pump. I am betting they sold him an A/C type 6 bladed pump. Y'all are shooting down the wrong snake hole. If it was a plugged radiator issue it would have gotten hot before and after the water pump change. It's getting hot only after the pump change. That is the only thing coolent related he changed right before this started to happen. Car is non A/C with the larger slower turning pulley, and probably has the wrong 6 bladed A/C pump on it. It's not flowing enough coolant for the impeller speed.
What year valiant?
Thank you Moparmat. You read the whole post and obviously it soaked in. LOL
It's a 1964 convertible.
After checking RockAuto for water pumps I noticed that all of the pics of 273 and 318 water pumps only show steel impellers with 8 blades. I'm pretty sure the new one I put in has the 8 blade not 6, but I can't be sure without removing it. My old plastic one has 10, I counted them today. Also, the new pump had three small outlet holes where my old one had two so I had to plug one. One is for the heater hose and one for the bypass, not sure what the third would be for, maybe the other heater hose in some applications. By the way guys, I didn't do this job because it was overheating, it needed a timing chain set and my boss talked me into changing the water pump too.
For some of the other questions asked.
No it hasn't boiled over, I won't let it get that far.
I don't know the temp, the gauge just has "C" and "H" and a couple of lines in between.
And no , I wasn't talking about a 60 degree day last fall, I'm not dumb.
The rad was checked and a new cap installed.
Timing chain was a typical and easy install.
Thanks again guys. Wally
Here ya go lol
Like I ask on every ''getting hot" or "overheating" thread, is it actually boiling coolant out of the overflow? If not, it's not overheating.
This is supposed to be an A/C NOS water pump. PN 3004763 I think the later '30' number denotes a later design year.
1965 parts manual shows a 10 blade plastic impeller but also shows 2 part numbers, A/C and non A/C for the 273
1964 Thru 1967 273 CI
1967-9 318 CI with A/C
1969 340 CI with A/C
I disagree, it's getting too hot...overheating. Boiling over is overheating to the max. We could agree to disagree though. :)
Yesser. Half way between "Keep an eye on it " and "Find a place to pull over" is where it was so I revved er up and it slowly dropped back down.
Normal operating temp on a factory gauge. Something is wrong if it runs less than half like you mentioned in your first post.
Until you put a real gauge on it you will never know for sure. A digital non contact thermometer will get you pretty close.
So there is a 6 blade! Well mine did have a ten blade, as I said, I counted them today (glad it didn't have 11, I would have run out of fingers and thumbs ha ha). So I wonder why they put a 10 blade on a tiny 273? I'm thinking I should try to have my old one rebuilt if I can't find another 10 blade at a reasonable price. Now I know what some people mean when they say these old beasts can be money pits. Wow.
Thanks Pishta
Dont trade your pump in as a core. Hang onto it. I bought a new pump for our 67 cuda 273 and the machined bosses for pwr steering pump and alternator were off. I kept my original and have since found an NOS one.
Your old one may come in handy for measuring etc. Rebuild kit?
I'm trying to find a rebuild kit but no luck yet. And I get what you're saying, I really don't want to let the old one out of my sight. The new one was an actual new one not a rebuild so I was able to keep my old one. Thanks for your post, Wally
