Add partial throttle kickdown to my 65 904?
briwill70
Portland, Oregon
Getting ready to pull my transmission to add a PTK. I have a 73 904 for parts and pulled the valve body. I think I read somewhere that some of the PTK valve bodies won't fit the early 904s. Is that correct? Hate to pull my transmission and discover that it doesn't fit.
I'm not sure if it will work in that year transmission but I do know you don't need to pull the transmission out to remove the valve body
You need a specific part that torquflitepatty on eBay sells. I believe if you don’t it will be a waste of time.
Jake
Supposedly a 67 upper valvebody half is required. Is TF Patty still listing? I was under the impression that he had retired.
Is TF Patty still listing? I was under the impression that he had retired?
That would be bad! Got a lot of good stuff from there...
