'69 Fastback Cuda Molding Clips
Norse
Gig Harbor, WA
I'm putting the interior back together and found a couple of the wire-n-fuzzy clips that hold the rear panel molding are dead.
Detroit Muscle is currently out of stock and don't know when they'll have them back.
Anyone want to Priority Mail me a couple?
Shoot me your PayPal addy and cost for mailing to 98329 zip code.
TIA
Are you talking about the clips that fasten the rear finish panel to the trunk lid? I might have a few of those. How many do you need?
The wire clips with foam that hold the 1/2" wide chrome trip that separates the lower panels from the window trim panels.
and if you cant find those//these work
napa
The tip on the 665-2829 clips was right on. jazak5, thank you very much.
I installed new ACC carpet in the 68 Barracuda and the issue is the covering for the sheet metal over the rear wheel wells is the same as the floor carpet. The OE material is much thinner. The OE clips are too short when used with the thicker after market covering. The 665-2829 clips are a perfect fit solution.
The OE clips are on the left, two of the 665-2829 clips are on the right. The bag had 25 of the 665-2829 clips, plenty with extras.
Jazak5
That could be just what I need!
I'm at the last steps of putting the interior back together and didn't want to have to wait possibly weeks just for a couple of clips.
Thanks!
