8 3/4 rebuild issues
38 Dodge
Biloxi MS
Thank you in advance for any and all help. Well I was putting 8 3/4 clutch pack back together and when I was bolting the 2 half’s together one of the case bolts broke. So I need to know if anyone knows where I can get these bolts.
3/8" grade 8 bolts, any good bolt store fastenal, McMaster Carr and many more.
These are left hand threaded bolts. I don’t know anyone around where I live who would carry them. I will check at Ace hardware on Monday
Thanks boy they are proud of them aren’t they. But they got what I need. thanks for the help
YES they are, but you can look around the internet and I bet you can find some cheaper.
I was hoping to find a pack and not spend all day searching the web. I will call them on Monday.
thanks again
i believe ARP has them -- 3/8 -24 FINE left hand thread -- McMaster - Carr only has left hand 3/8 - 16 coarse thread -- if you cannot locate a bolt ( good luck ) and do not want to spend what ARP wants for them -- take a spare ring gear bolt cut off the head and get a regular grade 8 bolt the right length and cut and weld the two together for the correct length,, if welded properly it will take the torque required.
Weld a bolt together? Man, that is hard up Sunday at 11PM stuff. Call the Doctor!
