Making progress on my Demon
could you use a deep/deeper drop base for the filter?
neil.
I have a drop base on it now..I'll probably just drop down to a 4 inch filter...If I drop it down anymore it'll interfere with the throttle setup I have on it..
Put a taller scoop on it. A real scoop. A HEMI scoop. lol
Where did you get the valve covers from ?
They're identical to Indy valve covers without the logo.
They wre $99 when summit first started carrying them , and I didnt pull the trigger .
I have the MP cast covers (currently on iron heads) and I'm constantly fighting leaks at the rear of the heads. Thinking of switching...
How do these Summit covers compare in height? I had to put in a shorter blower motor just to barely clear the right-side cover.
I dont have them , but I think they were 3.25 or 3.5 tall.
Ur lucky , I had to go to a hotrod heater under the dash , my raised port heads are about 3/4'' off the firewall on the pass side .
The valve covers I have work pretty good on my Indy Heads because the valve cover rail on my heads are wide..l used the blue Moroso rubber style valve cover gaskets.
I also removed my heater and blocked the hole off with a block off plate.
These work pretty good
It's been saying that on their website for a while. I'd like to get one soon. Is yours for sale?
No, sorry... even though it bounces a bit, something has to support my tach. And I can't hold it in my right hand because I have a 4-speed, even if I'm not petting the dog
