Utah Members
jau126
'65 Dart GT 273 904
Salt Lake City, UT
Looking for any members in the Utah. I am looking for a good machine shop and head porters.
I have heard stories around SLC while I am out about a few Barracudas so hopefully they/you are on here.
I used American Cylinder head in Salt Lake to freshen up a 340 for me. There was an old timer there that really knew his stuff. Its been awhile so I don't know if he is still there.
I had Jensen Machine in Ogden build a 408 short block for me recently and they did a great job.
I've also heard of shop in Utah County called Strasburg Machine that is supposed to be a mopar shop. Have never used them so not sure about them.
Did Jensen just assemble or also do some machining? I have a 273 that needs work that would be easiest just to pull the motor so it might get a full refresh and hipo pistons.
I live 20 mins from Jensen in Northern Utah, they assemble and machine blocks.
I'm looking for a good trans shop.
Both. I supplied the block and rotating assembly and the did the machine work and assembled it.
Not sure on a trans shop..
I called around for my 727 and either got a crazy quote or you could tell that they didn't know what they were doing. Ended up doing it myself, not as bad or scary as you might think.
