One of none
But is it numbers-matching? :)
Is that a coolant line coming out the front of the valve cover?
I hate to give info on this engine, as I don't know much about it, except it is very inovative, and fast. It does have a Billet aluminum head, fuel injection on alcohol.
I'm pretty sure that line is for a engine evacuation system, and goes to a vacuum pump
I'd bet it is in a Blue notch back 'Cuda whose name escapes me.
could be a Duster 240 cubic inches +- and around 400 hp, supposedly built a few years ago.
Could be crank trigger, for triggering the ign, and using the distributor for routing to the plugs. Distributor would have nothing to do with timing.
