Help cooling 408 stroker
Finally had 2 spal fans, 2 spaw relays, and went with 50% antifreeze 50% distilled water with a bottle of water wetter. Can seems to be running cooler ran around 210 out here in Cali while its 99 degrees outside right now.
Can you tell us which fans and shroud you are using in these pics? From your later posts, it sounds like you are now happy with your set-up? Like you, I have about 2-3/4" to 3" clearance from the water pump pulley bolts to the radiator core. Champion 3-row so I'm trying to solve the same problem as you before I finish my build. Derale makes a single 17" fan (2400 CFM) and shroud that may be able to be cobbled a bit to work. Thx!
Fans are both 10 inch Spal fans with separate relay for each and the shroud is custom built and fitted by a local machine shop. Have zero issues now with this setup.
I'm curious, how much did that 4-row Champion radiator cost you?
