Trick flow vs Edelbrock heads
Early a body
Nevada
Does anyone know what Trick flow has to offer over Edelbrock. i have used Edelbrock in the past, just curious now that we have Trick flow as an option.
Big or small block and what do you mean, what does it have to offer over the Edelbrock head?
Small block, meaning is there any benifit trick flow has over edelbrock straight out of the box? i am looking for anyone that has done a comparison of the two by actually testing them out.
I made the switch myself.
I would not go back to a Edelbrock RPM head and then port it to match the TF’s.
Pictured below,
Top, Edelbrock, the next two, the TF’s.
Mike @B3RE did up a 416 with the trickflow heads right out of the box, with no mods other than a spring change and it made somewhere around 630hp..
