Stop in for a cup of coffee
Made the bracket to hold little skulls. Dab of urethane will hold them in place. Then built a t-stand to support long items in vise, as its such a pain in the *** to balance stuff while adjusting things. Driveshafts are a perfect example, for doing u-joints. Was going to fasten it to bench, but i can use it for other things too.
A couple coats of silver on back of second small skull, as soon as it flashes off i will hit it with black. Now to see how amber lights look in grille skull.
I'd bang an elf!
That or im going to use it as a radiator overflow tank.
I found this in a box today.
Might be the only part I have left from the pair of cars I had that this is for
Got a few little wiring ends tied up, brake warning light and backup light and switch. Just have to go find my old tractor headlight to hang in the back. Time to go for a trudge...
What is it? Will it fit my Buick?
That is the lower taillight trim for a 68 charger. I had a pair of 68 chargers but I don't miss them. They went to good homes and the past is the past. Seems the taillight trim wanted to hang out some more.
My 65 build.
Here's what I've done to my Buick so far. I think after im done with the front end im going to make a thread here. It should get interesting after the front end rebuild.
My 65 build.
I don't know anything about Buick, but that looks like a sweet ride and fun project
Are you going to daily use it ?
