[WANTED] Mechanical [ REV-LIMITER ]
Just a FYI,
I have a cable splitter for a mechanical rev-limiter, if needed.....
Here is what using one of the Stewart Warner cable splitters looks like.
I have some cables for the tach to the gauge. Also a nos splitter, no rev limiter and NOS 5" SW cable drive gash mount tachs. No limiter, a few on e bay right now 150 and 250.
Im eyeing those I will hort up a few
I need to send u a photo of my gauge maybe u have a mount for it and whatever u have I need we will get that finalized and on the way ok thank you
Chris
Chris, one thing to watch out for if you are actually going to use it is that the majority you see are from HD trucks and have a range if 3500 to 4500 rpm. There is normally a sticker or tag with limit range. You have to look for the old moroso or DC ones if you want the 6 to 7 grand range or higher.
Chris, one thing to watch out for if you are actually going to use it is that the majority you see are from HD trucks and have a range if 3500 to 4500 rpm. There is normally a sticker or tag with limit range. You have to look for the old moroso or DC ones if you want the 6 to 7 grand range or higher. View attachment 1715660454
Ok that helps
Thanks for info
I cant buy one or them unless seller can guarantee what specs are
We can run an msd but u just have to hide it so I have an alternative
I was gonna make a snarky comment about weakass valve springs, but then......
I have a tachdrive distributor and moroso tach, and never knew such a thing existed! Learn sumpin new every day!
Good ole [ US ] technology
