I'm finishing up my mild 360.. I'm going to switch over to a MSD Streetwise box versus the factory ecu and ballast... what is a good distributor to run with this? also coil choice. should i go with a stock vacuum advance, aftermarket vacuum advance or go with an aftermarket mechanical advance? I'm still learning so be easy on me
