Help destroyed 7 1/4 in a /6 dart
ok got a lead on an 8 in out of a 1965 mustang will it fit
Yes, it should bolt in as the spring perch width is 43". However, the pinion is not centered, it is offset. I think it's around 1.5". I don't know what effect, if any that would have. I do know generally, you want the drive shaft to be parallel with the car's center line. Using that rear end.....or any 8" for that matter, will result in the drive shaft being offset in the rear. I believe it would be acceptable to run like that. See what some of the other guys say.
