Broadcast sheet info
Swamprat17
New Member
Nebraska
I've got a question about my broadcast sheet for my 70 Duster
On line 2 under axle it says D53 which I believe means 3.23:1 diff. Then on line 4 under axle it says 019. Is that maybe the code for the housing?
Thanks in advance!
Thanks in advance!
D91 instead of 019? D91 is Sure Grip
The 019 and 007 would be assembly codes, housing, gear, sure grip, brakes...
Alan
Thanks for the replies!
Here is some more info.
The first picture shows axle code D53 which I believe means 3.23:1 gear ratio and just left of that is a one in the box under D91 S/G that i assume is a Sure Grip code.
The second picture shows the other axle code. It is hard to read, but I think it says 019.
View attachment 1715665549 View attachment 1715665550 Thanks for the replies!
D53=3.23:1 ratio
D91= Sure Grip
019 = 8.75" Axle assembly
But mine has an 8 3/4 and has a 007 instead of 019 in that box?
Probable because you don't have sure grip and/or your brakes are a different size, it is an assembly code (actually the last three digits of the assembly part number).
Alan
