[WANTED] 1964 904a transmission (push Button) torque converter.
Stinktooth
Active Member
Sayville,NY
Rating - 0%
0   0   0
Wanted local pick up for Long Island N.Y. 1964-65 , 904 torque converter I think its a 18 spline shaft. 66 and up will not work with my push button trans.
Actually, 60-67 will work. If you don't find anything locally, I have a couple, but I'm in Florida
The LA motor was first produced in 1964 so what would fit on that from 1960? A converter from a slant? I am trying to learn about these things so I don't trash the input shaft on the transmission. I had a tranny shop already destroy the tranny when he put a later model planetary in the unit and then hooked up my original Torque converter, it sounded like a blender when the engine was started.
I have one from a 65 Barracuda .I'm in Huntington Long Island and the factory ones are the same for the six and the 273 in 65 and 64 .Probably a little later too.What is it going behind ? Where you run into problems is with the crank flange on the later 68 and up motors.They are a different size .
I am in Sayville
I need a core to send out. I have the original 273 and tranny for the valiant but need a core to have set up for 2400 rpm stall. Doing a cam and head swap on the motor.
I am in Sayville
Biltron builds them and they are right here on the island .They will make it to whatever you need and are reasonable Rebuilt Torque Converters — Biltron Quality Automotive Remanufacturer
I had one made there with a later front and the earlier back when I put in a later motor in front of the 2 cable trand in a 65 Valiant .They are very good .
Your welcome ! I've used them a few times and so have a few of my friends. If you still need a core let me know I have one I can dig up.
I stopped in and spoke to the owner, he said he could help me so I am planning on getting my converter to him this week.
Thanks for the info
