Stop in for a cup of coffee
Cam card
One piece left to weld on. Had 2 fires, first one was a rag 4 feet away, lit from grinding. Second one was my flannel shirt.
not a winter driving car
yep. They’ll clear by more than an inch on each side. Front will clear by a little more than 1/2 inch, IF I don’t roll/trim the fender lip.
Really? What did you do to get clearance? O this is the car with the Dana..... Never mind
Problem I had was the clearance when turning. Front hitting lower fender corner...
Looks to clear , I’ll get pics later. I’m using a REAL deep backspacing. With steering lock to lock, I barely have 1/2 between the tire and the frame but it does clear
My dart. I had the dana 60 custom cut to fit these rims and tires. Plus I did those big *** tubs
I will end up rolling that quarter lip anyway. Just to give more room to get the tire on and off with out having to go and drop the axle
