Stop in for a cup of coffee
Morning, just saw that Hank Aaron and Larry King both passed away, wow. Rip
I waited on Mr. Aaron a couple of times in Atlanta, he had charisma. I served Mrs. Aaron too, separately, I think they were separated maybe. Anyway she looked just like Jiminy Cricket.
Hay hay hay !! Let's start this Saturday morning our way
Ooooh boy!
Goooood morning Pete !!
It's a sunny day here on the hill (as I set drinking coffee quietly, Treva is sleeping in this morning..
Have a grand day my friend, Keith sure kept me busy on my visit..lol
That’s awesome!
Well, i better get on with it, chatting with a buddy, hes going logging today. Going to run a wood forwarder. 8 wheel drive with a grapple. He gets to play with all kinds of big machines.
I get to weld, grind and fill..
Finish up those cab corners? A bigger job than I thought.
One done, one piece left to weld on. Today m setting up the flir,to document heat travel while welding. Curious minds they say...
When the body shop did my 66 they used a wire feed that uses brazing wire. And he still got some warping. Not bad though.
Mornin yall. Yall think that gal up there ^^^^ needs warmin up?
Silicon bronze wire. Lower melting point,and weld wont rust. And maybe more malleable.
There will be warpage, the whole idea is to minimize it. I brazed panels on,way back when, cooling with wet rags as i went. Could feel the metal pull as it cooled. Tried heat shrinking back then too, could never get it. Now i think i could. And now its a shrinking disc, mounted on a grinder. Should look into getting one.
