Narrow Bearing Options
thomasfouraker
Jacksonville
Anyone aside form Clevite that makes a narrow bearing for an undersize .010 360 crank with factory journal sizes of mains 2.8095-2.8105 and rods 2.124-2.125?
Thanks!
Thomas
Well not sure why you want narrow bearings for a factory crank or if you mean narrow main bearings but I'm gonna go ahead and say I use King CR805XPN and yes they are available .010" J.Rob
Sorry, should have been more specific, it’s a 4” Eagle forged crank. The std. clevite 77 rod bearings I removed had signs indicating it was interfering with the fillet on the crank. Plus the machine shop kept the radiuses on all the journals when they ground it.
DODGE King XP-Series Rod Bearings CR 805XPN 010
Thank you all for those suggestions and post.
Seems like it isnt just the Clevites that are hard to get ahold of. Guess alot of people are building some forged mopars! Can't blame em!
They're in stock at Motorstate under KEBCR805XPNC010. Find a Motorstate dealer and get the 1 set they have in stock. J.Rob
clevite has a rod bearing, #CB 1386P, std, .010, 020, 030. it fits 239 V 6. .735 wide just food for thought.
