Calvert mono spring question
Firedart
Member
Arkansas
I found a pair of Calvert split mono springs someone locally has posted for sale for 200. My question is would they work with my car. I have a 70 swinger with a 7 1/4 currently but I have a 8 3/4 from a b wagon car that I’m wanting to put in. Says they are split mono 2000 but I can’t seem to find info online to see if they would work. Anyone that would know anything please give me a heads up. Thanks! I attached a picture file from his ad.
Did you ask the seller what car they were off of?
No he states they are 1” lower springs for a body mopar. I assume that by the photo he posted that they were for a 72 dart. They were never installed though which makes me wonder
There is no difference between the 72 and 70.
if the spring is an A-body spring it should work
"What else" are you going to use with your suspension? Those are particularly for use with the Cal-Tracks if I am not mistaken.
I believe RRR is correct, to be use in conjunction with CalTracs.
Got the part numbers from the seller. Everyone is correct that they are made to be used in conjunction with caltracs. Thanks for the info everyone
