A Bodies Only Member's Discount
just order!
Pitman Arm
(PIT18758)
So far my car has:
PST 1.03 T-bars
PST Idler Arm
PST Aluminum Tie Rod Sleeves
No complaints!
The rest of front suspension is all new P.O.L disk brake kit w/tubular upper control arms.
How do you like that 1.03 torsion bar? I'm about to pull the trigger, but some hesitation about too stiff of a ride for a regular driver.
I did a bunch of research before buying a set of 1.03" torsion bars from PST on a stock suspension '69 Dart with a 340 and A/C.
What I found is that mostly everybody from what I could tell, was happy with them. They did provide a firmer ride but not too harsh.
The price alone makes them worth a try $215 with the FABO discount vs. around $400 for a Mopar Performance set.
I went with them because I have my ride height set pretty low and the frame constantly hits the lower control bump stops.
I haven't installed them yet though.
I actually emailed James at PST about the ride quality on the 1.03" bars and this is how he replied:
I have had numerous inquiries very similar to your application and engine specs, each of them have had the same concerns as you. All of them ended up buying our 1.03 torsion bars and have never been happier with the decision. With the clocking that has been designed into our bars you will still have a quality ride with a modern feel even at a lowered ride height. Please let know if your have any other questions.
I have the 1.03 and think they’re worth it on my 67 barracuda 360. I also have the epso HD 6 leaf and they complement each other nicely. Ride quality is good and the car is on rails. Stiffened it up enough to reduce the sloppy body roll but not harsh either on the bumps.
I installed ESPO HD leaf springs a couple of weeks ago.
Now I'm working on my front suspension with PST 1.03 torsion bars and new bushings all the way around.
Can't wait to finish and see how the ride changes!!
I used the 1.03 bars on my 67 340 Barracuda. rears original HD with an extra full length spring (7 leafs) and a 3/4" rear sway bar. Ride isn't harsh just stiffer like modern. The part I like the best was when I went Bilstiens all round. They made it handle.
Thanks! I almost forgot about shocks. I still have old Monroe shocks.
I can see how they would round out the suspension after all other upgrades.
How'dee all...
I've been in the process of getting ready to upgrade my Torsion's on my '68 Formula-S 340 'Cuda and was planning on going with the PST-1.03's... I honestly hadn't given any thought to the shocks being a factor in the equation anymore than just requiring shocks in general. After reading a few different posting on the PST-1.03's I've realized that its a necessity... I've heard many of you mentioning the "Bilstiens", however nobody has mentioned "which" style of Bilstiens should be considered. Can I get some suggestions..? Also, while I'm at it, my rear springs are stock, all be it new'ish, their stock performance springs... I'f I'm putting in the PST-1.03's, coupled with 'which-ever Bilstiens are suggested, front & rear, are there any suggestions that I should consider for new rear springs to accentuate the all-around ride performance..? As I said, I have a '68 Formula-S 340 4-speed Notchback Barracuda...
Any & All suggestions would & will be greatly appreciated..!
Thanks in advance...!
#BIL7056063 from PST,,,,put your new bars in and drive it and then put the Bilstiens on and let us know. I don't regret getting them at all.
First I’d like to say thanks for your reply! Secondly I would like to verify if that SKU number is correct? I went to PST site and found that SKU number with the shocks however it doesn’t list anything from the latter part of 60s for a bodies just 70 Series A-bodies within the product details section...
Thanks Again!
Thanks Again!
...all set... I contact PST and they looked into them and called me back with the good news... so I ordered their Deluxe 1.03’s & a full set of the Bilstiens... although the 1.03 adjusters won’t be available until sometime in April, at least the balls rolling..!
Thanks Again...!
Thanks Again...!
I like to change one thing at a time to feel what made what difference, I'd like to hear what you think. cheers Larry
The Forum Member’s Discount:
· Forum member will receive 10% off any order over $200 dollars or more
· ORDERS BY PHONE: You will need to ask the salesman for the discount and say that you are a member of A Bodies Only. You will also need to give the sales person your USERNAME on the forum. (we will verify that you are a member)
· ORDERS BY INTERNET USING WWW.P-S-T.COM: Placing your order by internet you will have to put in the comment section of your order the forum name and your USERNAME. (we will verify that you are a member) The Discount will be applied when order is processed.
Ordering instructions and discount worked like a champ. Thanks
A previous owner installed 0.92 bars - but on close inspection they are both Left bars! No wonder it was hard to remove one...
Also need to change the steering box and it'll be a lot easier with the K-frame dropped (451 & B-body headers).
So I just ordered mine online :)
Just wanted to update, I got the discount, many thanks to James! And thanks to pst, my car is back on the road and actually driving straight!
Good job James.
I will definitely stick with PST for parts on my other car.
-- The Forum Member’s Discount:
· Forum member will receive 10% off any order over $200 dollars or more _ _ _ _ _ _ _ _ --
-- Hey Johnny Mac -- That's a good idea. and make it retroactive. :rofl:
Thanks! I’m rebuilding the front end in my 73 Dart Sport now. This will help!
Can you get the Black Friday discount and the member discount?
Asking for a friend...
I am sorry but we cannot combine offers.
Thanks
James From
PST
Too bad PST does not have a Canadian outlet.
As for the snow storm, we will be getting the one they had starting sometime after supper.
Sorry but i have to giggle at americans that get a foot or two of snow and the world comes to a halt for them. Being a canadian i am aware of our hottest is their coldest at the border line. Just saying.
Get a snowblower
Get a four wheel drive
I love snow. The dogs and I can play outside for hours at a time...... Love it.
I don’t know about that....
The tough people of Buffalo have had their fair share of “minor” snow storms.
The tough people of Buffalo have had their fair share of massive snow storms.
View attachment 1715684621 View attachment 1715684622 View attachment 1715684623 View attachment 1715684624
oh how these photo's bring back memories of my childhood living in Valcartier in Quebec. Twice in my life i had to jump out of the second floor bedroom window to dig out the front door to let the family out to shovel the driveway so dad could get to work. Then the grader would pass by and fill up the driveway again. fun fun in the sun right? P.S. Ever had crank bearing's stick to your fingers trying to build a engine in a non heated garage? It's kind of like sticking your tongue on the school fence post and not learning the first time it was not a good idea the first time.
