Post your wheel and tire combos.
Looks
Not as nice as a lot your cars, but here's my '66 Valiant. I bought a set of 14x4.5" steelies and some Toyo 185/75s to put on them. The tires showed up and I realized they were gonna be way too tall for the fronts. Decided to keep the 13s up front and put a new pair of Uniroyal 155/80s on those. Scored a nice set of dog dish from a fellow boardmember to class things up a bit. Pretty happy with the stance, but I think want to drop the whole car an inch or so.
Looks good
Finally got my Christmas presents mounted. I like it a lot. Wheel Vintiques cop wheels and factory dogdish caps. 215/65 15 front. 245/60 15 rear.
1967 Barracuda notch back
Front
Wheel Brand-American Racing Torque Thrust 2 515
Size-17
Backspacing-5.48”
tire size 245/45/17
Suspension mods- disc break upgrade, rebuilt LCA, bilstine shocks
Rear
Size-17”
Backspacing-4.81
tire size-245/45/17
Suspension mods-8.25 rear ended swapped somewhere along the way.
Thanks to all who helped me figure out what sizes would work.
Front
Size-17
Backspacing-5.48”
tire size 245/45/17
Rear
Size-17”
Backspacing-4.81
tire size-245/45/17
Hot damn she pertty
My '71 Duster with its new shoes - SBP Cragar S/S. 15x7 in front (bought from a fellow FABO member), 15x8 in back 4.5" backspacing.
Tires are 275/60's in the back and 215/65's up front.
It'll be nice to swap between the two looks.
Front-
Centerline Convo Pros
15x4” I believe unsure of the BS
165/80/15
Rear-
15x8 w/ 5” BS
275/60/15 Nitto DR
Suspension mods-
Comp engineering shocks all around
Stock front end components
002/003 SS springs
Springs relocated
Mini tub
Stock Abody width 8 3/4
How's the turning ability with the 15's (do you have manual or power, stock or tight ratio)? Do they hit the front fender on hard turns (i've heard from some that can happen)?.. Thanks!
Turning is fine, no interference. Stock ratio power steering. Could probably space it out another 1/2”-1” without issue. Front is currently sitting about 3/4” off the bump stops
SOMEONE PLEASE HELP
i have a 68 valiant and was wondering if these wheels will fit (have usct spring in and willing to do more mods if necessary)
Wheel Specs
front
Wheel Diameter - 17
Wheel Width - 9
Lugs - 5
Offset - +24mm
Backspacing - 5.95
rear
Offset: +20mm
Backspacing: 6.29
Weight: 22 lbs
Lug Pattern: 5 x 114.3
SOMEONE PLEASE HELP
Wheel Specs
front
Wheel Diameter - 17
Wheel Width - 9
Lugs - 5
Offset - +24mm
Backspacing - 5.95
rear
Offset: +20mm
Backspacing: 6.29
Weight: 22 lbs
I don’t think that front wheel will clear the outer tie rod. Depends on brakes, but I think a 17x8 with 5.5” backspacing is about as much as you can get on an A body in a 17.
Just put these on. Real pleased with the look. 15x5.5 factory BBP in the front with 165r/15s. Wheel Vintiques 15x8s BBP on the back with 275/60r/15s. Car is mini-tubbed.
I needed new tires this summer so I decided to change wheels also. I'm ditching the Cragar Quick Trick wheels and went with American Racing Torq Thrust D black. I've always liked em so now I got em.
Torq Thrust D 15 X 6
205/65R15 Advanta ER700 tires
All the same size so I can rotate when needed.
Front
Size-17
Backspacing-5.48”
tire size 245/45/17
Rear
Size-17”
Backspacing-4.81
tire size-245/45/17
HOT!!
67 Fastback
Front:
Cragar Magnum 510
14 x 6, 3.5” back space
BFG Radial TA P205-70-14
Rear:
Cragar Magnum 510
15 x 8, 4.5” back space
BGF Radial TA P245-60-15
