Shmaako
Installed new McLeod diaphragm clutch, removed the clutch spring above pedal, and had no where to hook the fork spring to so I drilled a small hole in the bell by the starter (as shown by yellow arrow).
I need advice on how to set this up. I read to have the throw out bearing barely touching the fingers but the pedal does not seem to have any spring to it...basically have to pull it back up...any advice or 'thread' someone can direct me to?
