Need help with wheel studs
RogerCox
Visalia Ca
I have a 67 barracuda (slant 6) 7 1/4 axle (5x4 bp)
what part number Dorman wheel stud do I need for rear, and what part number for front?
seeing so many options, thanks for the help!
RH thread for passenger side & LH thread on the drivers side too.......
Mopars from factory had idiotic LH threads on drivers side front and rear. Those can be changed to RH thread if you want.
Disc/drum are different studs.
If noone gets you numbers here, go to Rock auto website and grab the part#'s
8” drum (inside measurement) on rear, drums on the front as well.
RH thread..??
Sorry 9” drum.
only one wheel stripped every stud off, (driver rear) all the others came off easy.
used Dorman 610-083.1 and worked great
The drivers side is left hand thread, which way did you turn to twist them off?
Sounds like someone had already changed the left front then. The studs were sorta copper colored, with an L stamped in the end of the stud. You can knock your old ones out for comparison for right hand studs. Think they changed over to right hand studs in '71.
Cruze, I had a 72' with left hand threads.
