Put two on mine, stacked plate design, had them directly mounted on the radiator when the car was a 6 cylinder and they worked well, now i have spaced them off the radiator, not sure if they will work any different or keep cool air from the radiator. I used 1/8 npt to 6an fittings and bent up some 3/8 hard line from trans to rad to coolers and back.
