[FOR SALE] 68 and 69 dart parts cars
Looking for a complete window washer system for an A Body from the reservoir to the squirt knozzles in the cowling if you have any or all of those parts please contact me
Thanks,
Scott
Hello, I’m restoring a 69 gt in France and i’m after the 69 upper body trim (plastic) fasteners. I collected so far 25 out of the 40 something required. Would you sell those?
Let me see if I can get you some. To be sure, we are talking about the white plastic squares that hold the trim on a GT, correct?
Needing the antenna (complete) off of the green car. Do you still have it?
I have a complete antenna from a 72 dart if that works for you
I have 68 two door parts car a 68 4 door parts car Witch is pretty solid and two 69 darts for parts located in anderson s.c.View attachment 1715691983 View attachment 1715691984 View attachment 1715691985 View attachment 1715691987
On the 1968 driver side quarter window there is a bracket inside that the glass mounts to and the bracket mounts to the window regulator I need that bracket can I get a price and shipping to 19709 thank you it would be on the 68 2 door hardtop car
Is the bracket on the lower end of the glass?
All those white plastic mounting squares for trim on my Dart are UV destroyed. They literally crumble in my hands. Sorry. Let me check a couple of other sources and see if they may have some.. Again, sorry!
Hi sorry I’m just seeing your post now... yes that’s the ones, the upper trims going front to end only on 69 gt. As said there should be around 40 of them on both side. Thanks for checking that for me:)
On the two door, do you have the aluminum trim that the door panels slide up into on the interior side?
