Cleaned my carb with Pine sol
jonnyrose
canada
I did a 50/50 mix pine sol and water 48 hour soak time,can't believe it worked.
As of 2018, Pine-Sol can be found on store shelves with an ingredient label stating "Contains Pine Oil" but this is not listed as an active ingredient. Pine oil in modern Pine-Sol seems to be added for fragrance only, as the product still uses glycolic acid as the sole active ingredient.
I’ve had great luck with with sno bowl. You must check it every 10 min as first it will eat the finish off and eventually the whole carb..ask me how I know . It hands down though it the best I have ever used and cheap. Can you say diluted hydrochloric acid? I had a carb once that looked like it had been snowed on as a result of
Electrolysis I was sure it was a goner. Cleaned right up
I've been using Simple Green 100%. Cleans everything better and does no damage to anything. No disposal issues for either also.
Is there only one "product" labeled "simple green?" And what is the best sources/ price you've found?
I think they have different scents. I bought mine at Lowes, 2.5 gal for $15 if I remember correctly. Aluminum seems to work well, but I watch it, rinse, and blow dry the parts when done. I only rebuild Carters, so, they are aluminum. It also works well on pistons.
