Upper Control Arms
Well quote me next time... jackass. Just trying to play
lol. I wasn't trying to be all that man. I was simply lettin you know how I want to do it, that's all.
I looked on the PST site and didn't see any specifics. Does anyone offer aftermarket upper control arms for or with the small upper ball joint? Thank you drive through.
And I usually try to be the stickler of the OP. Calling people out. Now who is the Jackass. Lol
Yeah I don't buy anything from Classic. Peter is a class act though if you can't get the QA1 UCA's used from cudamike.
Of course it's a better way. More expensive sure, but better usually is. Offset bushings will get you at most around +3.5° of caster. At most. The QA1's should get you closer to +5° if you want it. No to mention less flex, and no 50 year old rusty suspension parts.
And no need for Moog anything, since the quality of Moog parts has fallen off a cliff. And they're the only ones making the offset UCA bushings.
I will be installing the QA1 UCA's with big balljoint as I upgrade my car from SBP to BBP. Please remind me: I will have 24:1 manual steering with 15x7 wheels and 215/60/15 up front. Would the best caster setting be larger than the Skosh Chart shows when I am looking for a balance of ease of steering & high speed stability?
Yes. So, in keeping with the categories on the SKOSH chart, I would say you can add +2° to the recommendations listed for the caster, keeping everything else the same. For example, “granny” would be -.25° camber, +3.5° caster, 1/16 to 1/8” toe in. “Max perf. street” goes to -.75 to -1° camber, +4.5° to +5.5° caster, etc.
With the QA1’s +5° will probably be about the maximum you can get anyway, although it will depend on your ride height and the alignment specifics on your car.
RRR, you can go to Classic, PST & some of the other suppliers & they will send a catalog for those of us who are internet challenged. LMAO
Last fall I tried to locate a set and no one had any in stock and could not tell me when they would be in. So I went with the QA1 uppers and boxed the LCA's and it worked out very well. Caster is now set at +4.5
That's what I'm going to do with mine when I finally get there.
FYI, I boxed the LCA's and used PST poly bushings with their greaseable spindles.
Made a noticeable difference.
I don't know what I'm gonna do on the lower bushings yet. I have some Prothane poly bushings. I think what I am going to end up doing is using those on the stock pins. I wanted the Delrin stuff from Bergman, but I am going to really have to make this budget friendly at this point.
what brand of UCA's do people recommend on here was looking at CPP and QA1's and what brands offer's the most caster built into them that are not fully adjustable with big ball joints
All the fixed designs are all the same in terms of extra caster. The QA1 is the nicest of that type.
However, with the other options, those arms are obsolete.
OK so how does the PST ones compare to the QA1 and how much do you want for the QA1's with the small ball joint?
and yes I know my first question was about the big ball joints
I was planning on going with the PST LCA rebuild kit.
I was gonna do the Delrin also but went rubber. Offset uppers and the now obsolete moog problem solver strut rod bushings
I don’t know what PST offers. My opinion was based on hands on fitment, consistency in alignment numbers and the gusseting and amount of material around the upper ball joint.
QA1 Upper Control Arm - Bergman Auto Craft
