You might be an "A-body owner" if......
You ask ... 'what's that' ?
You have to explain to the clone car guy who insists his 71 Swinger with bumblebee stripe and worked 360 is factory original, including the paint that " that isn't the original paint on your car, MOPAR didn't paint the dash and tops of the interior doors sublime green (body color)...:lol:
... If body colored paint behind the front grill annoys you.
Believe it or not my 74 dart sport came with black paint behind grill but not all the way up just as far as the angle would let you see from 20 feet
(unless it's a black car of course)
You might be an A body owner if:
You find the build sheet under the seat and decide to spend $400 on a one year only radio delete plate and think it's a good deal.:BangHead:
One of my pals has a 64 426!max wedge Plymouth has the owners manual for it in a blackout box it says and I can’t remember the exact wording but something like if you hold the gas peddle to the floor for more than x number of seconds you will be going 130 mph. Car had no back seats it was stripped out of the box. supper stock car awesome
Or , have to wait 2 months on a set of r/b , A body headers !
Or have to remortgage the house for the original a body big block manifolds!
You might be an A body owner if you have taped a piece of cardboard between trunk lid spring rods.
if you think the best place to jack up a car is your home made frame connectors
or...one of my favorites...if you use the fill valves for you air shocks to mount your license plate
.....If you bought a '70 Swinger 340 with plans to tub it, and stuff a big block in it, only to find the complete build sheet under the back seat, and discover every part on your car is numbers matching original, and it has factory AC.
Found all the build sheets for my dart. It is a complete #s matching car with original paint, spare tire, and 52000 miles on clock
...and STILL cut it up to race it, since its "only" an A body
