Too much timing?
I disconnected the coil and cranked the engine over a few cranks. 150 psi is pretty close from what I've read. I may be under 10:1 some that was original figures and after I checked my valve to piston clearance I never worried about it anymore. Let me run the numbers again and see what I get. I know I was .012 under the deck with 5 cc flattops 65cc heads and a .050 head gasket i think my original numbers was with a .028 head gaskets and I opted for the thicker ones.
That .050 number sounds like uncompressed thickness. What brand gaskets?
I don't understand why you guys insist on running so much timming on your mild motors. There is absolutely no reason to run 20degs initial on a mild small block, especially when your total is way off the scale.. Most mild SB's run just fine around 12-34. If you are at a track, ok try some different settings. But for an every day driver/street car, there is no reason to ring the car out on the jagged edge over timming it. 12-14/34-36 will be more than sufficient.
I don't understand why you guys insist on running so much timming on your mild motors. There is absolutely no reason to run 20degs initial on a mild small block, especially when your total is way off the scale.. Most mild SB's run just fine around 12-34. If you are at a track, ok try some different settings. But for an every day driver/street car, there is no reason to ring the car out on the jagged edge. 12-14/34-36 will be more than sufficient.
Because of low cylinder pressure. There's nothing jagged edge about it. If it can stand 20 initial limiting total to 34-36, without spark knock and without kicking back on the starter, why not do it? It will run much better. His camshaft has a good little bit of duration, too and that will always benefit with increased initial timing. It's no secret. It's been in the MP engine books for years. ...and not just in the race section. It's very beneficial on the street, as it keeps temps down, make for a more efficient and complete burn. There's absolutely no down side.
Well, you can talk about all the Mopar books you want, but if he keeps driving his car at 20 initial, 40 all in, he's going to have problems. You even had your slant motor way over timmed, until I mentioned slants don't like a lot of timming. You lowered your timming, all is good. Its just a mild small block, no reason to run the timming on the ragged edge.
Well, you can talk about all the Mopar books you want, but if he keeps driving his car at 20 initial, 40 all in, he's going to have problems. You even had your slant motor way over timmed, until I mentioned slants don't like a lot of timming. You lowered your timming, all is good. No reason to run them on the ragged edge.
He told the OP to cut the total back. Damn. No one is killing anything with timing. Unreal. I’ve run my 11.25:1 junk with 36 total locked out. Never killed that piece of crap.
Take it easy, its just discussion. No reason to get all upset.
36 total......very reasonable.
My 318 loves 20 initial and 40 total. Track proven. 140 cranks PSI
Which is why I suggested he not continue driving it. Are you even reading either of these threads? I knew mine was overtimed right off the bat but didn't want to fine tune it until I knew the cam and lifters were broken in. Go read the thread buddy. I didn't put the timing anywhere because you said so. lol Your input is appreciated, but I ended up where I am because that's what worked.
Ok rusty
And that 36 total was 36 initial too. Didn’t kill it. I’ve run some stuff as high as 42. That’s what it wanted.
And I won’t even discuss that fact that timing light accuracy varies so much it’s not funny. My timing light may say 36 total and yours may say 34. It is what it is. What the plug says is what matters. The timing light is just a number.
I’m not upset. Seems you are. You lost your mind because someone didn’t run the timing you think is best. Go read your own posts.
No, it's what works for his and a lot of combos. You do what works for yours, right? Why can't everybody else?
You show me where I said everybody else couldn't. Its just my observation of different posts, and timming issues.
Lost my mind ? Hmm
I agree with you on timming lights, timming marks, inaccuracys etc.
You didn't. But to the contrary, no one is suggesting to you to run a different timing setting than what you're happy with and works. Right?
That's all we're trying to do. We're making suggestions based on what's worked for us. Not running down what you've done, like you are us.
Hay, if his car runs good at 12 initial and 34 total and he's happy, great! IMO, I think it will want more, but the suggestion is to "try" a particular setting and see how it runs. If it spark knocks, kicks against the starter or anything else out of the ordinary, then I would make a different suggestion. I want what's going to work best for Kevin's motor. Whether that's 0 initial or 35 locked out or anywhere in between.
I don't know. Maybe "lost his mind" was a little tough. Johnny's pretty particular about how he does things. You ever seen his under hood shots? Chit man, I wanna go over and eat pizza with him right off the valve cover. His attention to detail is fantastic.....if his stuff runs good where he has it set, I believe him. He just needs to understand there's more than one way.
As far as initial timing goes.......
The factories had to be conservative...& probably erred on the side of caution....when specifying the initial timing.
As for the OPs situation.
It doesn't matter where the cam is installed or what the cranking pressure is. He has found the 'sweet spot' of initial timing for THIS engine, 24* BTDC. His test method was quite legitimate. If the engine & starter tolerate it under all conditions, all well & good. Some engines wouldn't, might buck the starter or ping. With this, the fix is manifold connected vac adv with an adjustable VA so that it can be properly calibrated.
OP, keep going you are on the right track.
For those who think 24* initial is a lot, Pontiacs with 10.75:1 CR, iron heads, & mild cams were driven off showroom floors with 26* idle timing [ 6* init + 20* added with MVA ]. I believe Chevs [ some at least ] had 24*.
I understand there is more than one way Rusty.
What I'm saying is that you don't have to pump so much timing into a car just to stick your chest out and say look at me, I have 20 initial. Maybe for a quarter mile blast. Backing it down a couple clicks will give you an all around much better running motor, that will also last much longer. No hiccups with the starter, no pinging, no knocking, no burnt pistons, and an overall cooler running engine. I also can run 87 in my cars, Have you seen gas prices in California ?
I'm sure Kevin will get it sorted out. :)
Thanks for the nice comments.
This comment cracked me up I’ve never in my life seen somebody poke their chest out and be proud of their initial timing LOL
Was the throttle open? Engine warmed up? How many cylinders did you test? Since the engine is fresh, it may be a good idea to test all of them and stash the results in a note pad as a baseline for use down the road. That's good info to have.
Either way, sounds like a good running little motor.
Engine was warmed up. Around 150 It was not at WOT. After reading some of these posts I didn't realize 140-150 psi was considered low compression lol my old 318 barely broke 90s haha
Im just trying different stuff. I have read different ways to improve performance with timing and tuning and im just trying it out. Im new to this part of it. Im just trying to learn. I agree it does sound extreme I thought it was alot of timing too that what made me want to ask questions. Im gonna have to limit my dissy either way. I originally set it around 14 and it runs good there.
Felpro 8553pt 4.180 bore. It doesn't have a listed thickness i measured it at .056 and figured it would compress .006. It may compressed more or less.
