pishta
I know I'm right....
The stuff between the roof and the drip rail...is it a mastic, ie. squirted in and let set or is it a piece of tar strip? Mine is seperating from the roof leaving a nice crack. 65 Barracuda.
The seam sealer that is out there is light years better than what they were using 50 years ago. You still need to buy the good stuff, not the crap at advance auto. 3M makes really good seam sealer. Self leveling works great but not sure how well it would work on the drip edge....never tried it there.
Im pretty sure the stuff mopar used actually absorbs water. Kinda like the filler at the quarter panel seam.
Dig it all out or it will keep cracking. Spray some primer, sealer or what ever you have on any bare metal spots. Lay a nice bead of seam sealer. Use a small brush or your finger with a glove on & some paint thinner to smooth it out.The stuff between the roof and the drip rail...is it a mastic, ie. squirted in and let set or is it a piece of tar strip? Mine is seperating from the roof leaving a nice crack. 65 Barracuda.
Its on a painted roof! What a shame.....I think it cracked when they used the infra red dryer after painting it...20 years ago.Dig it all out or it will keep cracking. Spray some primer, sealer or what ever you have on any bare metal spots. Lay a nice bead of seam sealer. Use a small brush or your finger with a glove on & some paint thinner to smooth it out.
