brake master cylinder
MOUSE
GLENDALE AZ
I have a 1970 dart. I'm having a hell of a time finding a master cylinder . front disc drum rear. Anyone have a source or a part number for me ? Also I have the 2 hole mount to the booster. THANKS
Post some photos of what you have.
Are you sure it is oem Mopar?
Power on no power?
It's a universal booster from classic ind.. I bought them separately in an effort to save a buck. Didn't know about the 4 mounting holes versus the 2 hole . Thought they were all the same. Oh well ! After a search on line , I think I'm going to buy a set instead of individually. They're more readily available.
Not sure what you are saying here. You are going to buy a proper Mopar booster and MC that fit your year????
It's probably for a Chevy. That's what most of the aftermarket kits use. We might could tell IF YOU POST A PICTURE LIKE YOU'VE BEEN ASKED SEVERAL TIMES.
That means it universally fits NOTHING.
FWIW The GM stuff has a 9/16-18 front port while Mopar is 9/16-20. Both use 1/2-20 rear ports threads.
