Just received part of my headliner from Classic.. It's a tier grain vinyl material.. When I ordered, I thought when it said vinyl, it would be VINYL.. This is soft, foamy material. Is that what tier grain vinyl is..???
I have a 72 Demon.. Originally hardboard liner.. No one makes those... I was told the ABS with vinyl would be closest.. It's NO WHERE close to what I had.. I'm just wondering if they sent wrong one... Or, does tier grain vinyl mean soft foamed material..What car is it for? Most all mopar used fabric headliners. 73 they switched to the hard board. Your picture looks like foam backed felt which is in no way correct.
That looks good..! So, if you get the ABS plain, is there a texture to it at all, or completely smooth. I may send back and just get plain...then do something to it.Yes, some 72's had the hard headliner. All 73 did.
The only replacement is the ABS one and you can get it plain or covered in the felt backed material. I was a test fit guinnea pig for those back when they were being developed. Still have the free one they sent in exchange for test fitting. Anyways, on my 73 swinger I ended up using the original board, laminated the topside with a thin layer of fiberglass for strength. Then I covered it in vinyl material. Pic attached. Yep its gator grain material I got from the local JoAnne fabrics.
