Alternator Amp test
Darren
ontario
Hey guys
I'm doing some work on my 68 barracuda.
It's a 383 S matching #. I have upgraded to MP electronic ignition and cracked back's headlight relay kit (that I still have to install) I want to leave the original amp meter (good idea ?) I bought a sunpro volt meter that I was going to convert and install in place of the amp meter in cluster but changed my mind.
Any way my question is..
Is there a way to test my current alternator to confirm the amp rating?
Can a alternator repair shop spin it up?
I want to leave the car as close to original as possible but want it to be safe..
The car has original radio.
Thanks for any advice.
Hey guys
You need a tester with a inductive amp clamp. (pickup) They are available as a accessory for a quality DVOM (digital volt/ohm meter) or as a stand alone meter like this.
Also, yes any alternator repair shop can check amperage output. And if you do keep stock amp gauge, make sure your bulkhead connector is in A1 shape.
So I assume you clamp around the alt output wire?
Is there a specific RPM or time (first start up in morning) to do this test?
Sorry for my electrical ignorance..
Thanks.
Yes I actually bought a new bulkhead connector and will be going through it ..
Thanks
Well there's more to it than clamping on an ammeter. You need a way to load the battery, the "go to" device back in the day was known as a "carbon pile" load tester. This is an instrument, often containing both a large value ammeter and voltmeter, and an adjustable carbon resistor, huge, 1 each, with a huge knob up front. You can simulate various loads at will as well as test starter draw, and determine battery condition.
Test procedures are laid out in the service manuals, and you can download many years from MyMopar....free
I don't recommend this brand--or not--just a photo for reference
If the car is running just turn on the high beams, fan, ac compressor, etc and see what the output is at 2k rpm.
True but it will give the OP an idea of wether or not the alt is operating correctly without taking anything apart.
Sorry it really doesn't. The headlights and such don't draw all that much in comparison to typical modern day alternators of 50-60 and more output. Many can do that much with a couple open diodes, even though this generates a lot of ripple. It WILL give you a "quick and dirty" idea that the thing is charging somewhat, and that is about all
That is a carbon pile battery load tester and voltage meter. It has a amp meter for testing battery load but no way to test alternator amperage output. It just measures alternator voltage output.
Of course you can use it to test an alternator. You simply use the device to create a battery load. You have to be able to load the system otherwise on a "big" alternator you may have system voltage "to the moon"
This is the start of the alternator output test from the 1972 Plymouth service manual. Please notice the bottom line.........
Loading an alternator unnecessarily without the proper equipment is a good way to release the magic smoke.
Have at it.
I have used the carbon pile test, but i dont go too far. Its not worth the risk.
In order to load it, you have to pull those amps through the bulkhead connector and ammeter. And all that questionable wiring.
Hi guys thanks for all the info.. I don't mind pulling the alt and having it tested if that's still a option..
Thanks.
Local parts store should be able to do it. Ask them what it is putting out they might just say "it's good" Napa is usually more informed on the older parts IMO.
A old friend of mine works at a local alt/starter repair shop.. maybe he can help..
Thanks again
Thanks again
Before you go to the parts store, identify the alternator.
See if its the original, or possibly the original for the engine.
Then copy the pages from the shop manual showing the service test.
This is the only reference I know of relating the 'rating' to an actual performance test.
If your friend's shop has more specific bench test reference, great. But I wouldn't count on it.
The AutoZone store near me does free alternator testing. After the test they provide a print out that shows max alternator output among other items.
Have at it.
Really? Then what is the risk of driving it that way (as we actually used to do) and burning up the stuff you just mentioned in "normal operation." That is the exact purpose of testing.............to find the **** and get it out of there If the bulkhead connector/ ammeter won't put up with a very short term load test, then maybe they are the problem........which they are..........
Some store / bench testers are "ok" and some aren't. The BEST way to test a charging system is "in the car" in which it is being used........as I mentioned earlier.......the "sections", the components, the output circuit, and the field circuit. Testing in-car can test the entire system as a whole.
Most bench testers don't have the horsepower to fully load a high output alternator. It takes a LOT of power to spin a say, 100a alternator up to full shaft output RPM
Remember the qu
Remember the only question the OP had was ‘what is the amp out put of his alternator’. He was not asking about a complete check of the cars electrical system.
