Quick question before destroy or buy wrong , I bored out my 340 to .030 and looking at summit ring compressor non adjustable size 4.030 , is this the correct size needed ?
You need a 4.070" tapered ring compressor. (4.040+.030 overbore)Quick question before destroy or buy wrong , I bored out my 340 to .030 and looking at summit ring compressor non adjustable size 4.030 , is this the correct size needed ?
Its always good advice , I always take care in the process , my cheap ring compressor is my biggest issue , thanks for the replyDon't forget rod booties. I hate being the guy to keep the rod bolts for hitting the crank and keeping it aligned. My dad send pistons in like he is hitting a grand slam.
"cheap" is your problem.I had a cheap adjustable and it moves to much and cant get the bottom 3rd ring to get past it as its the thinner ring an shifts just enough to cause an issue
