Turns signals don’t work
Sirsmiley9
Florida
After I’ve replaced my ignition module for a 1976 duster none of my turns signals work I don’t have blinking left or right in the dash or from front and back lights
Do you mean the ignition switch? If so it should have been a simply uunplug and plug back in. Was there anything else you had to do to replace the ignition switch. Are you sure it was the correct one for your car, compare the terminal locations from old to new.
No it’s the box in the engine bay the ignition system connects to I don’t know how it might be related but it only happened a day after that
seems unrelated. do your brake lights work? Could have been a fuse that blew maybe just a coincidence it happened at the same time
Fuses can look good but still be bad inside the ends where you can not see.
Pull each one and do a continuity test with a multi-meter.
Also, did you move or bump any wiring / connections during the recent repair?
If so, something may have come loose.
You said they don't blink, do they light up but not blink? It could be a bad 4 way flasher. Do your hazard lights come on?
No they do not I’m not sure if some wire could have been knocked out of place while messing with my coil or ballast resistor.
do you know if there’s some way to test the turn signal switch
I'm sure there is, but I can't help you there. It could very well be the switch in the column. How does the lever feel? Tight with signal cancel working or lose and no cancel? (When it worked)
it felt a bit loose but the cancel worked and you could feel it click in however it seems if you hold down the lever it flashed once and another time flashed slowly and this was for left blinker and right
Usually a good place to start is to check your grounds.
Which fuses were bad? What circuits are they? Did you check the fuses again? If you have a problem with the wiring in that circuit it will just blow again so recheck the fuses.
Check the wiring on either side of your bulkhead disconnect, especially on the interior. Look for any melted or deformed insulation. Look for wires stuck together with melted insulation- not just at the disconnect but anywhere up under the dash. get a mirror and flashlight if you have to. Mopars are alias for problems with that. That's a whole other topic to talk about with some preventive actions you can take.
You need to get yourself a wiring diagram/ service manual---the CORRECT year as 76 has a lot of changes from 74 Find the two flashers there is the signal flasher and the hazard
The hazard flasher has power at all times
The TS flasher gets power when key is in "run"
Pull down the connector at the column for the TS switch get a test lamp/ meter and go to work. First with the key "on" check for power from the signal flasher. Turn key back off. Check for power from hazard flasher. Then check for power from the brake light switch with pedal depressed. The switch receives power at all times. Check for brake lights. If you have power TO the switch and not OUT of the switch you are starting to look at a bad switch. Wiggle the **** out of the hazard switch. The hazard switch can develop problems and screw up the signals/ brake lights
The hazard flasher should have black and pink wires, so the pink at the TS connector should be hazard power coming FROM the hazard flasher TO the switch
Tan and light green are the two front signal lamps and cluster indicators
White is switched power from brake light switch coming TO the TS switch
The bottom wire black, is horn switch
TS flasher has black and red wires, so red at the TS switch is power to the switch from the flasher
As just stated 1976 has a lot different from previous years.
You may find the turn signals do not have a fuse. They probably figured the flasher would act as a breaker
Hazzard on '76 has its own direct line from the battery, with a fusible link.
And about fuses..........NEVER "check" fuses just by looking at them. ALWAYS take a light/ meter and see if you have power out of it.........under a load.
