[Found!] door locks w/ key and letters 65 dart
hosehead
Springfield Mo
Looking for the "R" and the "T" for a 65 dart. The ones on the quarter panel. Also a pair of door locks w/ a key so I can lock this thing.....
PM me if you have anything. Thanks
If they car still has the door locks just send it to a lock smith and have them make a new key that’s what I did for the locks. It’s going to be the same as your ignition key if it wasn’t switched.
I thought the door key was round and the ignition was pentagram? 2 different ones...original 1965
Your door key looks to be an original, but, not the trunk/glove box key. They should have the same type eye sticking out from them as the ignition key. If the OP's door cylinders are broken, I should be able to put together a genuine '65 matching pair with an original style key. If they just need to be re-keyed, I can do that too, but, it would probably be cheaper to have a local locksmith do it, and as mentioned, have them pinned to match your ignition key.
cool, Those were handed to me when I bought it out of a warehouse after 25 years of storage.
Thanks Mark, I just bought the car and it came with one door/ignition key. I'll have to copy that and then try and get the locks I have rekeyed.
The problem for me is I live in rural Oklahoma with not a lot of anything around. I'll research a locksmith I guess but I wouldn't be surprised if I had to drive out of town a fair bit to find someone to do that.
Send me a pm for what you'd need to purchase a set of locks with a key. Thanks!
