[WANTED] 65 barracuda interior trim-below rear glass
Lurch59
South Dakota
I am looking for trim, I believe 3 pieces total, that attaches across the back glass and 2 L-shaped curved pieces that are associated with it.
These pieces the plastic ones inside under the glass and the 2 “L” shaped ones at the front inside bottom corner?
I think we are talking about the same trim pieces. The interior piece under the glass has 4 oblong vents (I presume they are vents) and the contiguous pieces on either side. I don't see pictures if you posted any. Thanks
I described them as L shaped but perhaps just curved transition pieces are a better description.
If you're talking about the plastic curved pieces, those are pretty hard to find that aren't broken. They get as brittle as potato chips after 55+ years in the sun.
This what your looking for
Yup. been looking myself. Thought someone was gonna repop them but no go. You can possible make something with vinyl floor edging and a heat gun. Or Cover the entire back support with same thick material and make holes in it for the ventilation. Looked kinda incomplete stock anyway.
Well, it's dark half the time so only like 27.5 years in the sun. We need repro parts!
If we do find some, they probably won't be rusty! I'm looking for a bright side, here...
The earth reclaimed mine too. And the small ones at the front corners. Going to hammer some out of sheet metal. Or maybe fiberglass.
I might have some chipped ones, but, no perfect ones for sure. The problem would be the shipping. It would probably take a fairly good size box to protect them, or, you'll end up getting a box of crumbs.
Not likely to be reproduced when so few are being restored, I suppose. I will see if the resto shop has any ideas. We must be getting close to scanning an original piece and 3D printing it, no?
The center piece doesn't come off, its part of the structure.
I just looked and it is part of the structure. I just saw 4 screws very near where the window gasket goes, and assumed that held the trim on. I wonder what the 4 screws attach to?
Thanks for the lead. Let me see what they can do at the hot rod shop that is going to assemble the stuff. Yours might be important to make a pattern.
