Snake
Mopar Nut
I have bean surcharging for a voltage regulator for my 71 but don't know what best on line, i have electronic ing now no points now.thanks again.
i have the bottom 1I assume you are talking about the voltage regulator that keeps the charging voltage to the battery in the 13 to 14 volt range.
This is the earlier single wire field (non isolated field) voltage regulator
This is the later electronic voltage regulator 2 Field wires (isolated field)
Which do you have now?
electronic vs point ignition system is irrelevant to the voltage regulator
So, are these even sold anymore?...........
...Or it was a way to sell a more expensive VR to hot rodders.......
Blue Streak? Haven't from that brand in a while. Who sells that? If you don't mind.i got 1 on order 57 canadaian blue streak thanks gents.
