Engine Vibration 3k RPM
plumkrazee70
Medford, Oregon
Hi everyone, I'm chasing an engine vibration (or at least that's what I think).
70 Dart
68 340
A500 OD transmission
Neutral converter
Neutral balancer
The vibration can be felt in Neutral when revving the engine to 3-3500k. It's not as pronounced as when it's wheels on the ground, at speed though.
The vibration goes away when the OD kicks on, which drops it to about 2200 RPM.
I thought it was driveline or pinion angle related, but I took it back to the guy who built the driveline and rear end and after we went for a drive, he doesn't believe it's driveline related. He even had another guy come by and get his opinion.
The trouble is, this is a new build (8+ years in the making) so I don't have anything to go off of.
Here are things,.I was planning on checking:
1. I was thinking maybe a misfire (not sure how to check)
2. It's got Fuel injection with timing control (maybe rotor phasing is off)
I wanted to remove driveline to be absolutely sure it's not rear end or wheel related, but not sure the best way to plug the trans. Will these work? https://www.oreillyauto.com/detail/...le-transmission-transaxle-plug-set/lis0/23400
Thanks for any suggestions.
If it’s worse in neutral, it is not the driveline or the rear axle.
check ignition timing at point of vibration
what are the motor mounts condition? All 3 ok?
Is the exhaust secure?
How about the harmonic balancer? What’s that condition and age?
If the engine received new pistons but didn’t get balanced (which is sometimes ok to do) than it may vibrate like this all the time at that rpm.
I wouldn't say it vibrates worse in N, I would say the opposite. Its worse when driving at that RPM.
All three mounts are new and in good shape.
The exhaust was just welded up (Summit kit w/clamps)
The balancer is new, but I would like to recheck the timing to be sure it hasn't jumped.
I can't remember if the engine was balanced when it was put together as that was 8+ years ago. I do remember KB hypers +.040, the crank and rods were what came with the motor (stock stroke). It was a very mild build as I wanted to have a nice driver.
What is the best way to verify engine balance? Does the motor have to come out and take apart?
Vibration or a miss/stumble that feels like a vibration. My 340 Dart doesn't like 3200. Just fine 100 rpms above or below
Oh, you said in the original thread post that it was less pronounced with the wheels on the ground, at speed. And that it can be felt in neutral.
As for your engine balance, go through all your documents and see if it was balanced. You’d surely know if you bought a balance job or not. It’s at least a couple hundred $. And with a good balance, they want to also have the flywheel/flex plate, balancer, and sometimes the torque converter. Not just a crank and block.
it would be my assumption that if the engine was not balanced, it would vibrate and has a resonance at that specific rpm range. I had a 360 with KB pistons, no balance and it would have a certain rpm spot it would resonate at.
try a carb spacer....really.
Umm.. no, it's up there high enough now! :D
could change the powerband slightly and possibly move your resonant vibration. Peace of mind that its intake related instead of balance.
Ok, you're right. I know for sure I didn't provide.them with the flex plate or balancer, because I didn't have the balancer yet. So it wasn't balanced.
This weekend, I plan on checking the rotor phasing and pulling the plugs to see what they look like.
I know mines fuel/carb related. Was just offering it as a suggestion to the OP that thinks he has an engine vibration.
I already have a 1" spacer. Mine could be tuning related. It has EFI and I haven't messed with it at all yet. Yesterday, when I was getting it up to RPM in the garage in N, easing into the gas, I could see the tach stumble right around 2500. It would drop to 2k and then it would rise back up to whatever RPM I was after. I didn't notice this when I would rev, but easing in it was noticable.
If it wasn't balanced, and you used KB pistons, there is your problem. The KB pistons DEFINITELY effect the Bob weight, your only fix is to disassemble the engine and get it balanced. Running it out of balance like you are, can destroy the bearings also.
did the trans come from a 360/5.9 vehicle, if so the convertor may have a weight on it? remove that and you 'should' be golden.
I am not sure what it came out of, but the converter I have was built for the combo and I know I specifically said Neutral balance. I'm sure there are no weights on it.
Understood. At least winter is around the corner. Thanks for the help.
Sounds like a fuel delivery stumble and not an engine vibration to me, why I questioned it in my first post.
70 Dart
68 340
Neutral converter
Neutral balancer
Lets do the easy things first.
Check the torque converter bolts make sure they a tight and loctite has been applied.
Remove all the drive belts from the front of the engine, water pump, alternator, etc with the car in park check for your vibration you may have a fan or pump that's going south. Make dam sure you do not overheat the engine doing this, start with a cold engine.
Post some close up pictures of the spark plugs so we can see the timing mark on the ground strap.
KB flat tops for a 340 are over 150g lighter than factory pistons...... each.
If the rotating assy wasn’t balanced, it really should be.
I pointed that out in post 14, but people are advising all sorts of other nonsense
"nonsense" hold on there partner, we/I are only giving the OP suggestions to check for it is up to the OP which path to follow. I agree that the rotating assembly could be the issue, but I would try everything else before I take the engine apart.
Oh yea. It's like a WAA WAA WAA. I called the machine shop and he said to bring it by and he could tell me if it was a misfire or an engine vibration. I don't really want to tear it apart, but I want it to be right.
yeah absolutely - you should be satisfied!
if you can verify it isnt a misfire, Id say its your rotating mass. i had a similar problem and it was a defective pressure plate.yes I know yours is auto but I m just saying it sounds similar. Mine was so bad the dash rattles sitting still
