At what point would you step up to ferrea hollow stem valves
What’s that valve length again?
I don't recall the actual length of my valves, but they were the long valves that mp sold to get a 2.00 installed height. You need that height to get enough retainer to guide clear because of the cam lift,
You also will have valve springs that will live longer because they taller. But this all makes the total assembly heavier as well.
Thanks killer6. I was having a Brain fart last night on there length.
Longer is heavier, but all so worth it.
So You wouldn't run a Hemi under any circumstances, I mean, a long valve with a 2.25" head diameter & a 5/16" stem is total catastrophe...
The NASCAR stuff is usually 2.14 on a 6 or 7 mm stem and run 500 miles at 9 k.
I installed longer 5/16 valves in my econo heads. The rocker stands were machined off when I bought the blown motor but had short valves. I am using T&D rockers.
I think we are getting off topic here. I never said that smaller valve diameters would break or that they cannot be reliable in a given
Setup. But if we agree that a hollow stem valve would be weaker
Than a similar diameter solid valve stem, then that same logic tells us that a larger diameter solid stem valve would be stronger than a solid stem smaller diameter. By some standards an engine that only runs 500 miles would not be considered reliable. How many miles do you think a pro stock engine sees. NHRA passed new rpm limits to lessen the teams operating budgets due to valve train component costs. Those motors won't see 500 miles before the valve train is serviced. Top fuelers even less, so like I said it depends.
The valve train setup is not really a sum of only one component, but of all the components in the valve train. Depending on the expected useage of the motor. IMHO
Conical springs come in double springs, not sure about triple. Less weight, lighter retainer. Never heard of beehive triples....
As I said, they were prototypes, the member even posted a pic(s).....hoping they chime in....I know IQ52 was retiring from this stuff....not sure which forum/thread it's buried in....
