[WANTED] Wanted to Buy - Mopar Performance Stage VI Cylinder Heads- P4876383 (Chapman, Standard Port) - let m
I have a new 4150 Mopar Intake new in the box for the Stage 6 heads
Thanks for the reply!
Is this standard width 440 or the extra width one that fits Stage 6 heads on an RB block?
Do you have the part number/pix?
Is it stock or modified?
Have a new pair of P5249579 Max Wedge Ported by Jim LaRoy ( IQ52) and his son Cody.
Max port might be a bit big for what I am intending (470 in, <6500 rpm) - sounds like serious race pieces.
Was hoping for the small port, long valve heads.....they may all be gone, but I can only ask..
It fits low deck as cast and High deck with a spacer on each side. It has a built
in valley tray.
That sounds like the one I am looking for.
What port size does it measure?
Can you possible post pix?
Do you have the part number?
Sorry for the barrage of questions - oh, and how much do you want for it?
Thanks!
Standard port.
$325.
It is currently on A and B forums
Brand new and uncut or modified
right out of the box!
Standard port.
$325.
Ah, I see that post - seems to be folks saying it only fits S6 on an RB with no spacers - ie; the extra wide intake is that correct?
Or does it fit S6 on a low deck - ie; same width as a 440 manifold.
Which is it? Thanks!
If u have Stage 6s on a low deck u can use a RB 440 intake. It’s a direct bolt on. I had a M1, Weiand dual tunnel ram and an Edelbrock TM7 on my 470. Kim
Agree. I was going to run a STR-14 I have with the MW Stage VI heads I mentioned above
Yes, thanks. That's how I understood it.
I had hoped/thought there was one standard 440/RB sized one with the integral valley tray.
A check of the old catalogues set me straight - no such beast. I hate valley trays on big blocks....
Still hoping to find the '383 part number standard port Chapman.
My friend dislikes offset pushrods, but a hemi has them pointing all over the place - shouldn't distress roller lifters
There is a 440 stage 6 intake in the sale ads by GTX John. It fits RB with Stage 6 heads. $325.00. Kim
Yup was taking with hi about that one - I'm looking at doing a low deck with S6 heads - so standard 440 width required.
I have a couple of 230 casting 400 blocks I'm toying with doing a project with
