Does this look weird to anyone?
I took apart a motor that I thought was a stock/unmolested 273.
It was smoking and using alot of oil.
After a Freshen up on the heads it was getting around 120psi in the cyls.
I pulled the piston with the lowest 115psi, removed one of the rings and put it back in the cyl
the End-Gap was around .132 - .134!!!
I was expecting to see an .020 gap, Was I wrong?
