[WANTED] 340 warranty block
j061093409
1970 Dart Swinger 340 Reg
Wethersfield, CT
Looking for a 340 warranty block with documentation. There should be rivets and a tag that say warranty. Needed for 1971 Dart. Since the warranty was 5 years/ 50,000 miles, any 1968-1973 blocks will do.
looking for original engine also: H1R263395 - probably in Alberta, Canada
Looking for a 340 warranty block with documentation. There should be rivets and a tag that say warranty. Needed for 1961 Dart. Since the warranty was 5 years/ 50,000 miles, any 1968-1973 blocks will do.
looking fir original engine also: H1R263395 - probably in Alberta, Canada
A 69 Dart? Not 61?
My 69 fish has a 383 Warranty block and is only stamped on the oil pan rail near the starter. PT383H25130103,
Translated is Power Train Trenton, 383, High, 5/13/69 and 103 engine that day. I believe! The website that decoded is now defunct and I did not record it all!
Have you checked with the guy working on Swinger GTs in Canada? He is here on FABO!
I have been told since 1968-72 cars were warrantied 5 years/50,000 makes any year warranty block is good. Must have a tag and/or rivets as documentation that it is a warranty block
Correct info - didn’t realize errors
