hotrod swinger
I’d like to see a picture of the finished product for the later square instrument cluster. From these pictures it looks like the top of the numbers would be cut off:
You might just finger out where to cut the screen with scale on it, make it work.I’d like to see a picture of the finished product for the later square instrument cluster. From these pictures it looks like the top of the numbers would be cut off
That will work but... everything that needs a chassis ground is still relying on the few screws that hold the panel in the dash for a ground path. You could add a length of wire at your screw by the speedo and route it to ground somewhere. Male and female terminals a few inches away from the screw and this wire will unplug next time the panel is removed.
I’ll correct myself: those were both attached to grounds. I think this will work though:
Any chance you can show how you connected that + lead under there?
I didn’t take a picture, I just bent a quarter inch spade connector similar to how the noise suppressor has a bent male spade.
I didn’t put the capacitor back in because I have a solid state IVR which renders it unnecessary.
@Moparmatt Old post, but I'm just starting the conversion. Wondering how the cover gets re-installed once the inside mods are done? Do you try to re-crimp it, or epoxy it together......Or maybe something else? ThanksWhile in there, why not remove the IVR out of the fuel gage, and wire in a solid state IVR, and install some 5630 LED strip lighting. For more uniform backlighting
I would suggest connecting the two heavy ga wires that went to the old Mopar amp guage together, connect a light ga wire to this same joint, connect the wire to the hot side of the newly configured guage and a second wire from the other side of the guage to ground. It is now a volt meter.
No, the original ammeter wires are "hot" all the time, so the voltmeter will sit there, always on, and cause a battery parasitic drain
You need to connect it either to "ignition run" (not fused) or in the fuse panel a switched wire on the accessory buss. Stay away from the fuse at the end of the box, INST, which is for the dimmer controlled dash cluster lights
