I've read a lot on the use of the 340 cam in the 318. With the 340 being a performance engine, wouldn't the duration at 0.050" be 228* on the intake and 235* on the exhaust? My question is, isn't that a lot of duration at 0.050" for a 318?
Mike I basically am running the same setup in my B Body 318 and the stock converter works just fine.Will it work with a stock convertor
I'm sure that this has been asked about a million times, but this time I'll write it down. I'd like a cam that has a decent noticeable idle, something more than a comp 268. Would a cam with 220* @ 0.050 and a 110* lsa workLots of companies make that cam. Summit racing has their own. Sum-6920
AwesomeI've done it, no issues. Performed well.
What cylinder heads are you usingNo it's not:
"With the 340 being a performance engine".
Now the 318 is the performance engine.
The unique thing about it, it's all mopar parts top to bottom.
But that's in a 360 and not a 318in a low-compression 318,
installing a 340 cam; 268/276/114+4, ( perhaps 208/215@.050)
with NO OTHER changes,
your cylinder pressure will drop about 15%, from about 134 to 115; due to the late-closing intake valve.
This will drop your low-rpm performance about 25% from a P/V of 110 to 84.
read about P/V here V/P Index Calculation
You will certainly be disappointed if you keep the current stall and gears.
The factory 340 cam has only about 44* of overlap, so the rpm has to be set very slow, and timing very retarded, to hear any rumpiddy-rump. IMO, it is NOT the best choice unless you already own it.
The comp Xe268 is 268/280/110+4 and is 224/230@.050 almost three sizes bigger and the overlap is 54* ; But the intake closes 4* sooner so not quite as doggy down low. I had a cam of about this size; 270/276/110/53* overlap and 223/230@.050; but in my 367 the lope was just barely noticeable at 700rpm with 14* idle timing. My Scr was 11/1 with alloy heads, and I had a 4-speed so stall was not an issue.
With either of these cams, your Scr should be brought up for best results. 115psi is not very much pressure.
Hence the advice of moving the stock cam installed 4*’s…..in a low-compression 318,
It does depend on what year. 70 318's compression dropped to 8.8 from what I have read. Different compression height pistons is what I saw. Were they still using the embossed steel shim head gasket back then?9.2:1 factory compression is not a low compression engine. Add in the thin .028 ths head gaskets and you are creeping up on 9.5:1
It's all good . . .
And a .010 ths clean up of the original Head. Yes Sir . . .
And no long draw out scientific babble explaining everything ether.Ok, this one made me lol. Short, but sweet.
